No fricken way does that engine run close to right with 12-15* initial. Get rid of that notion. My 340 with a 241 at .050 cam has 24* initial. Starts up in 100+ degree weather with a flick of the key.
It's going to want in the 20's, where you are. Let the engine tell you, not some notion or desired number that you feel is correct.
