I'd take a close look at the lever in the center of that wear. Bet you find a cracked lever or the pressure plate is cracked near it.
Yes, right In the center of the spots is that lever. Could be anything mentioned, broken bolt, something cracked, bad/weak spring, pivot worn, heights not equal.
OK pink slip, what are the last three words in my post above??? Thanks for your deception!
