Originally Posted By barracuda7199
Dr diff 1" spring relocaters will let you bolt in a 68-70 b body rearend. Then you can run 10" wide wheels with 5.5" back spacing. Using this setup I have 325/50's under my 71 cuda.
iagree That is the set-up I have under my Cuda, too.
Master, again and still
