I'm using a set of the "LE" door panels from a 90 on my 85 crew cab. My question is was there ever a cheap fiberglass knock off made in this style? What I want to do is cut down a set to fit the rear crew doors and glass them back together. Could this be done with the OEM panels, and how would you bond them back together?
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
