Originally Posted By Azzkikrcuda
Do you really need a spacer since you are filling the trans to the same Level as before work
I’ve wondered about this as well. Other than promoting better circulation at the bottom of the pan for cooling I don’t see what difference it makes assuming you keep the fluid level between the marks.
