Thanks for showing the trim ring stud repair details! I assume you use body filler on the top side of the stud?
Are the original studs cast as part of the ring or where the studs inserted into the ring as it was cast? Mine has a few broken studs.
**** They are cast as part of the ring. The top is finished with an epoxy steel and /or filler can be used.. Very little is left to fill on the ring ! what is on the top in the photo is panel bond from the installation of the bolt.
