Sounds like you will be junkyarding it. Ramcharger have tilt more often than pickups
Note 2wd and 4wd use different intermediate shafts so keep yours till the swap is done. Or get a column from a similar equipped truck.
Could also call the dealer for a factory pn then check fleabay for a listing.
Angry white pureblood male
