Nice thing on an MS3Pro which is like a lot of the other high end systems is cylinder trimming.. This was some we did cruising on drag week on the set of Moran billet Atomizer 2's.
Also some of the datalogged info from a run. I do like the way megalogviewer shows data.
Easy to tell not enough fuel pump and injectors at 100% duty cycle... Things to fix! Also RPM should have drop.. smile
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
