Originally Posted By Stanton
Replacing bolts with studs usually don't warrant a line hone.
So I won't be having you build any of my motors!!
1) Stud torque is different than bolt torque
2) Bolts are installed with oil - studs with ARP lube or similar
You sure as hell DO want to line hone if switching from bolts to studs !!!
No problem there!! Check it both ways ( factory bolts and studs ) and see what the bearing clearance difference is.
Fastest 300
