I'm gonna try to post 3 pics of how I might lay out the gauges. Which one might look best?
Make sure you put the gauge layout in the dash pod and sit in the drivers seat to determine how easy the various gauges can be seen. It sucks having to dodge around trying to see the oil press. or water temp. or whatever because the wheel blocks your line of sight. God, I learn EVERYTHING the HARD way. I'ts going to look great when your done.
