My brother recently bought a set of valve covers from Arruzza for his new 528 hemi. They are supposed to have more width to clear the Indy roller rockers that are on his motor, as the covers we are replacing (brand new and now junk) cracked because there was interference with the Indy rockers. *SIGH*
The problem is, the new, wider valve covers are also taller, .100 to be exact. Cant go much thinner on a valve cover gasket to compensate because Greg from superformance told us a stamped cover needs about 3/16 gasket to seal, no less. Aruzza also sold my brother Indy length tubes (.500 longer than stock
smh) for the extra height, but they stick waay out the top and no way no how they will compress the oring at the top of the hole. More $ down the drain.
Apparenly Mr. Arruzza will not take returns. So, does anyone know who makes custom tubes without buying high quantities?
