Originally Posted By cnxt
It sounds like the fan needs at least 20A constantly when running?
What kind of alternator you running?
I'm running a magnum based motor so I'm using an alternator that can handle the output. I wouldn't be able to if I were still running the one I had before this motor. I would've upgraded to one of the aftermarket bolt ins, or the one of the Denson units.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
