Watch the gov sensor actual and desired pressures, if they are not the same switch em both out. Get the big BW solonoid. There is not a governor switch just a pressure/temperature sensor and variable solonoid.
Sounds like I need a scan tool for that.
![blush blush](/ubbthreads/images/graemlins/custom/blush.gif)
The kit I installed had the following in it-
This Kit Includes the following Components:
Governor Pressure Solenoid - Heavy Duty Borg Warner
Governor Pressure Transducer (Sensor) - Oem Mopar # 56028196AD / 68164850AA
Output Speed Sensor with O-Ring Installed - Oem Reference # 4800879
3-4 Accumulator Spring .126" , Upgrade
Filter
Governor Housing Base Gasket
Neoprene / Rubberized Pan Gasket (For a Quality Seal)
Tim
