It came out of a 1970 B-body high performance Plymouth or Dodge produced at the Los Angeles plant. It was probably delivered in late November 1969 within a couple of weeks after the engine assembly date (11/4/69). The block is worth a couple hundred dollars but maybe a couple hundred more to someone who is looking for that date and a couple hundred more than that if it has a good original forged crank with it
