Mine broke 38 years ago. None of the gears or anything else in the chain were cracked or damaged. Just the pointer broken. Drove it 20+ years that way with the pointer still on the bottom of the speedo. Finally opened it up to repair the trip odometer and while it was open I repaired it by super gluing a small strand of copper wire in the v channel of the pointer joining it up. I painted it with Coast Guard Orange model paint. Has been 5 years since the repair and it is still holding up. The damage can also be caused by a foreign object getting into the magnetic drive at the rear of the speedometer. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
