you are seeing the needle opening and closing. You will also never "push" fuel through the jets, thats not how a carburetor works. The bowls are not pressurized, they are filled to a level set by the float. If the needle was stuck open and the bowls were allowed to completely fill under pressure it would come out the vent, boosters, etc.
