Listen to what Trendz wrote. Others have mentioned there is no way the car can run at 19:1 a/f under load, and both sensors are reading lean. There is likely a wiring problem, and you can start by checking the voltage being read at your data acquisition unit.
'18 Ford Raptor, random motorcycles, 1968 Plymouth Fury III - 11.37 @ 118
