Hi 340 clone, your B body set up will work although 71 E body as the flat switch plate on there wiper motor compare to the big plastic cover on 72 and later model As you said you will need the switch ( 3 speed/variable ) unless I am mistaken dash wiring is the same. I will try to get you the part number for the switch.
