IF you are using an infrared exhaust temp gun to check the headers;
Do you check it right after you make a run?
What RPM do you check them at?
What header temp would be ideal for the perfectly jetted carb?
I am assuming there is a percentage you want each header tube to read in relation to the other header tubes?
How do you use yours?
thanks
Jerry
Old Geezer Racing
