496 12-1 indy ez heads 630 270 roller 3" exhaust 9.71@140
426 11-1 eagle heads. 600 250 hyd. 3" exhaust. 9.88@134
Same converter and gear
I think there is a good advantage in weight reduction going to the G3 over an RB, no?
Only draw back seems to be the cost. Do you know the approx cost for what each mill cost you?
The Wedge I am guessing is in the $7500 range, but the G3 with headers and ignition has to be closer to +$10k I was thinking....Love you car and combo by the way...Seems like it does double duty really well. Which combo did you prefer driving wise and did you have the GV unit with the RB?
short blocks cost what short blocks cost basically for any combo or brand.
my eagle heads were $422 and I ported them.
My apache heads not on car yet cost 1200
My EZ heads cost around 2k and I ported hem to MW port
My BB had $700 harlands. My gen 3 stock rockers
headers same cost really. Actually I bought my fenderwells for the BB for $700 and got $600 for them when I sold them because the price went up so much. paid $740 for the TTI's
ignition, same, when you add Dist, Coil and 6al to Hemi 6 controller
I could go on and on but it all costs the same when you figure it out except I think the hemi block is better, the stock heads are better and if you want to go boost it would be easier
I just sold the GV. I want to stop being so slow at drag week. My car is going on a diet and will be faster next year.
I doubt I lost all that much weight going from the BB to the hemi. 100lbs maybe
I think if I was a little more aggressive with the hemi it would be just as fast as my BB was. little more comp, a little more cam, etc
