What we have here is a '68 B body, manual shift, power steering column. I've blown the column apart for a resto and have the shaft out, but the lower bearing is pretty much rusted in place. I'm not concerned with saving the bearing itself, but I do want to preserve the nylon piece so before I go all Cro-Magnum on it, I'd like to know does it:
A) Slide towards the steering gear box (short end)
B) Slide towards the steering wheel (long end)
C) Does it not matter as there is no shoulder it butts up against.
