Sure, but will the valves float? Probably.
Best help, with the limited info given, is to do what the cam manufacturer recommends.
A number of things go into determining valve spring pressure requirements, lift, rate of lift, rpm, ect. None of which we have.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
