Well, I guess my next question is, what regulator do you recommend? I've been looking at one from TrickFlow, 4.5-9 psi. Has 2 outlets and is rebuildable should the need arise. With dual outlets, could I install a pressure gauge in the second outlet and get a correct pressure reading?
