Originally Posted By 3csalvage
remove or cut the hoses to splice them, flush backwards with water coolant out of the heater core,blow out as well I don't use compressor(too much pressure) then fill with white vinegar let set 10 minutes or so flush and refill! Low cost works most of the time!
I just back flush mine with air, but I turn the pressure down to bout 25 psi and did quick burst. wave
