Re: Part # Strange double adjustable coilover rear shoc
[Re: DRAGRCR632]
#201264
01/23/09 07:43 PM
01/23/09 07:43 PM
2 most common stange shocks are 5006 6 inch travel shock 13.875-14.500 installed length or
5007 which is 7 inch travel shock 15.25-16.00 installed length
both are double adjustable i stay with the longers ones just depends on room you have
LRT
thanks but....what spring weight would you go with on a 65 plymouth 3445 lb w/ driver.thanks
