There are options all the way down to 3.08 gears for the D60. If you need taller than 3.08 gears you need an over drive, because you have compromised low (1st) gear.
Please tell me where I can get a new D60 3.08 gear!? Everything I have seen so far shows 3.54 is the closest that's currently available.
Same here, never see anything below a 3.54 for a Dana.
