I would like to recheck float levels. Service manual says to bring up to the bottom of the site plug hole. I'm aware the ones on the secondaries sit lower than that of the primary. Other sources I have say get clear site plugs and bring float level of center carb up to bottom of site plug hole and secondaries to middle of clear site plugs. Another says bring all up to center of clear site plugs. I don't have clear site plugs so my float levels are factory spec. First, I'm not sure which plugs to get (part #?) for Holley 2300s. I see several different options online. Second, I've read horror stories about plugs breaking off and/or dissolving/turning to mush so I'm hesitant about messing with them at all. Thoughts?
