Originally Posted By kz5rt2
Just out of curiosity, what is the easiest way to get the run/start wire to the ignition box?
On my '63 330, I used the factory harness and connected the blue wire in the harness to the run/start wire in the MSD box.
My MSD 6AL is mounted under the battery and you really can't see it unless you look really hard.
