Something to think about: The input shaft was hollow to direct the transmission oil pressure to apply the clutch assembly in the torque converter. It re-directed the oil from the cooler lines in high gear lock-up. Thoughts were that in lock-up the torque didn't slip so No heat build-up. Lots of burned up 904's pulling trailers. Definetly not worth the effort to make the switch.
