Originally Posted By 71_Demon
No shifter or linkage. The only other stamping on it is C99129. I know I can measure the retainer but that can be changed.
That's not a stamping , it's a CASTING NUMBER and it's useless other than it being the casting number of a cast iron maincase , the same casting was used for all 833's .
If it's a 75 A body trans it is probably a non OD.
running up my post count some more .
