The wires that go directly to the dome light are black or black & brown, they connect to a plug on the drives side either roof pillar area in 1/4 or behind the rear seat on the frame work. The wire is pink to that connector. If you pull ether kick panel out, you can see the connector that plug into the door switch and as stated before it should be hot all the time.
Switched to the dark side...
