Bought a thermoquad that runs well once off the idle circuit.Will not idle well(like a big vacuum leak).Don't care to mess with it so who would you send one to to have looked at.Only interested in knowing what the problem is and how much to fix(if fixable).Then I will decide if I want to spend MORE money on it.
The motor it was intended for has a carb now.I could use it on a smogger 440 if it does not become cost prohibitive.
Thanks and yes I know I am lazy.
