Big question- Did you take the tension off the bars by backing out the adjuster bolts? They go from the bottom through the lower control arms. They Don't just fall out, they just may need some force to get them out. Lowering the k frame will put a bind on them, leave the k on or near the frame rails. Pull the k forward, hit the bars from the rear with a large punch and drive them forward.
