It didn't have a plate. Extension sits on thick washers then the rubber mounts. Same on the underside. Rubber mounts then thick washers and then the nuts. Should there be a plate?
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/ motormangj@gmail.com
