Originally Posted By rebel
Leaking from the bolts seems a bit strange to me. Have you checked the oil pump to block gasket & the O rings on the oil pump body?
I agree, I think they only way they could leak is if the O ring or gasket is leaking.
Now I need to pin those needles, got to feel that heat
Hear my motor screamin while I'm tearin up the street
