I know for one, I APPRECIATE the time you take to show your work! It sure helps guys like me with there build.
Say Pat, can you tell me why your putting the torq boxes in now without the weight of the motor?
Don, I did install the frame connectors when the car was complete and on the ground, and with the frame connectors installed I didn't see any problem with adding torque boxes when the car was on the rotisserie. It is so much nicer welding right side up instead of upside down ;-)
Thank you!
Pat
