4.250 stroke crank with 2.200 BB Chevy rod journal sizes, 7.100 long BB Chevy H beam forged steel rod, shelf piston with either a reverse dome or a dish that will give you between 10.0 to 1 to 10.7 to1 compression ratio with the aluminum heads you buy or lower the compression ratio to no more than 9.5 to 1 with your iron heads
![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
True roller timing set and degee the cam you select
![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
Six paks rock
My last 400 block 518 C.I. stroker six pak motor made 720 HP with 712 Ft lbs on Oregon 91 octane pump swill
![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif)
That baby put many smiles on my face as well as made the old phincter pucker more than once on the street
![devil devil](/ubbthreads/images/graemlins/custom/devil.gif)
