I picked up a stand from Northern tool, looks to be decent but I had to do some changes.
I narrowed the front beam 3" to 24" and moved the fixed welded wheels to the front and I moved the front Casters to the rear, I drilled a through hole in the rotating head to have double shear on the pin and I added a clamping bolt to the hinge point to make the stand rigid when in use.
