Originally Posted By StageIII
Did you you port the heads or run them stock? On what inch motor are they on?
Edelbrock is a great vendor, but I'd still disassemble them, do a bowl blend, clean/check the valve job, and check the guide clearance. No need for porting on a street engine.
