The Hedman fenderwell headers that Sixpackgut mentioned are something that I always wanted to try as they made more power than anything else on several cars that I read about.
If you run the hedman fender well headers don't you also run into tire clearance issues where a taller tire will hit plus you can't make Sharp turns without them rubbing. I'm not sure just asking
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
