I'm looking at picking up a very clean 97 Dodge Dakota, 4x4, extended cab or is it club cab....very clean no rust. It has the V8 magnum engine, which is the 318 I believe. Mileage at just under 200k, which is 120 for you U.S folks.
I have no experience with the Daks, any advice or things to look for?
What are the weaknesses or faults of this model dak?
From all appearances the truck has spend a lot of its life indoors when in use and when not in use.
Thanks,
