Originally Posted By RapidRobert
I measured several SB tubes/sticks recently for a guy & to my surprise they all varied. If you get no answer & if you definitely have a std 4 qt SUMP pan I'd put 4 qts in with the car parked on a level surface & mark the stick at that point
iagree scope twocents
BTW, what year E body and 340 motor? I think the early 340,pre 1970 motors, had a shorter tube and dipstick, maybe not confused
