what about in my case where the machine shop took 16 thou too much off the passenger side when they were asked to zero deck the block? everything else checks out fine but my flat tops are 16 thou out of the hole on the one side.
Cut the block so both sides are the same. Use thicker gaskets or put the pistons in a piston vise and machine .016 off the top. Since it's a FT you could do it in a lathe too.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
