For a '68 B body car you probably want to hang the calipers to the rear. In that case I'd use the late model FMJ calipers since they are designed to be rear hung. They have the inlet and bleeds in the correct location to be rear hung. Then you'll need to have a set of custom brakes hoses built and you'll be all set.
