There is a lot of ways to wire this, but if the switch doesn't cut alternator charge off, that wire can keep the system charged as the engine slows down. If you have ever seen a throttle stick and the battery switch is turned off, its a LONG time before that engine stops. This can be several seconds of a fuel pump running pumping fuel someplace you don't want it to go. Please consider this important safety factor.
