When you push the button the amount of air going through the carb really drops off. The more you spray, the more it drops off.
I would think on a 500" motor, that a 1050 would be plenty once the button has been pushed.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
