Thanks for the tip on the RV jacks. That's much cheaper than the 3" square tubing I was considering and no fab time! I will definitely be making a Walmart run for those. I will probably add a jam nut like you suggested for added security.
Anyone have suggestions as to where is the best place to check for level front to back? I am thinking just use the door sill?
Those stands make it easy to level. I use 8 of them so I can adjust the end extremities as well as the passenger compartment area. Door sills right next to the pinch weld will work for front/rear level. Using the FSM body alignment measurement you can then check the extremities for level against the sills.
