I use a hose clamp & a pair of pliers to get the shields out
Go ahead & break the top of the plug off & blow all the crap out around it
Use a short socket & once you get it turned a little spray it with PB or a good penetrating oil Move on to the next one till you start over
Thy're still not going to come easily & you will coat the new ones with Never Seize
