I went out and purchased a $149 caster/camber gauge 2 years ago, already used it four times.
Check toe with a tape measure.
I usually do alignments on my four post lift. I have a large 8 foot level I used when building the garage that I utilize to make sure the lift is level before proceeding.
Easy to adjust the cables to make sure everything is perfect.
"I think its got a hemi"
