What all will I need to make this conversion? I am not trying to get increased spring rate here, just bigger rotors for braking when towing.
I know the inner bearing on the rotors are different. Are the spindles different sizes, or is the different size bearing due to the diff rotor?
Looks like they both use the same caliper but different caliper bracket.
